Lenovo 320-14iap no power needed bios `
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Lenovo ideapad 320-14iap
    dg424/dg524 nm-b301
    rev 1.0
    2017-03-09
    no shorted coils i think bios problem or ec
    backup also here
  • peste
    • Dec 2016
    • 12786
    • ROMANIA
    Re: Lenovo no power needed bios `
    try post#4...
    https://www.badcaps.net/forum/showthread.php?p=900975
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Originally posted by peste
      tried it sir no power
        • 20865
        The bios linked to by peste is good,test all voltage and signals on page 48 of the schemmatic.
        https://www.badcaps.net/forum/showthread.php?p=907334
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          Hi sir can you please check my bios it for
          DG424/DG524 NM-B301 REV 1.0
          2017-03-09
          motherboard cpu is
          SR2Z6 Intel Celeron N3450
          SERIAL NUMBER PF12DQM0
          LENOVO 320-14IAP
          Please check if my bios is back or need clean sir update
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            Originally posted by kalilinux25
            Hi sir can you please check my bios it for badly need it to clean its me region
            2017-03-09
            motherboard cpu is
            LENOVO 320-14IAP
            it my backup
            Hope someone can clean this bin and clean me region also.
              • 20865
              If you must post images post them on badcaps please.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                ok noted .
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  I taught I need to use other link for images, now I know so I can use the badcaps
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    Why if I used a latest bin from official website it wont power the board? Do I need also to flash the EC bin? , but if I put back the original bin it will power the board , but it has a issue stock on windows loading screen even live os is tested.
                    this is the ME Analayzer showing the backup bin
                      • 20865
                      320-14IAP Laptop (ideapad) - Type 80XQ 5RCN**WW
                      Flash the bios and EC -> https://www.badcaps.net/forum/showpo...78&postcount=4
                      Copy your DMI from your backup using the attached CopyDMI script .
                      Copy DMI info easily with Hex editing software and Macro script: https://www.badcaps.net/forum/showthread.php?p=1214739
                      0x0421000 - 0x0422FFF
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        Thanks sir wwhat a great help Ill test it again sir after 2 days
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          Re: Lenovo 320-14iap no power needed bios `
                          Update regardign about this unit it was not about the bios it was a very tiny rust in the ec chip , I really need to invest a microscope now a days, but thanks for this
                          • Duranitron
                            • Jul 2014
                            • 544
                            • Philippines
                            I need help guys, Need bios dump of dg424 dg524 nm b301 rev 1.0 attached is my backup bios,
                            need clean ME.
                            Model no: LCM 16H5
                            Lenovo P/N : SN20M61837
                            I can't find the serial number. There is no bottom plate label in the laptop
                            FYI: I attempted to extract data from my device using an EZP-2010 programmer, both with and without a 1.8V adapter.
                            Comparing the extracted BIOS files using WinMerge, they were identical. .
                            Thank you in advance.
                            Never stop LEARNING because life never stops TEACHING!
                            • shiyab
                              • Sep 2023
                              • 1451
                              • india
                              need clean ME.
                              Model no: LCM 16H5
                              hi try
                              • Duranitron
                                • Jul 2014
                                • 544
                                • Philippines
                                Originally posted by shiyab
                                hi try
                                Thank you bro. Hope it works. Post the result later..
                                  • 20865
                                  need clean ME.
                                  Model no: LCM 16H5
                                  Posts moved to 320-14iap thread. Your model and serial 320-14IAP Laptop (ideapad) - Type 80XQ , S/N PF0W4B0H
                                  This bios has your DMI info ,SN etc.
                                  • Duranitron
                                    • Jul 2014
                                    • 544
                                    • Philippines
                                    Thank you very much SMDFlea! Gonna try it and post the result here.
                                    • Duranitron
                                      • Jul 2014
                                      • 544
                                      • Philippines
                                      Thank you very much SMDFlea! You're a life saver! Your bios works like a charm.. All voltage are correct 5v, 3.3v, 1.8v in bios..Gonna test again
                                        SMDFlea commented
                                        Editing a comment
                                        You`re welcome :-)
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • grimacelord
                                      Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                      by grimacelord
                                      Hello there.
                                      I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                      History:
                                      1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                      I searched for this error online and discovered...
                                      03-15-2023, 03:29 PM
                                    • cyber16
                                      Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
                                      by cyber16
                                      Please I need help.
                                      Quick rundown long story shorter, but still long winded.
                                      I received this Lenovo P1 GEN 1 about a year ago from a business.
                                      It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
                                      At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
                                      Then late last fall my father-in-law suffered...
                                      09-08-2022, 07:32 AM
                                    • Joluvillas
                                      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                      by Joluvillas
                                      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                      06-18-2024, 10:35 PM
                                    • baaligoga
                                      Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                      by baaligoga
                                      Good day, everyone!
                                      I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                      I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                      05-20-2023, 09:48 AM
